Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Installed version 4.4 no longer working since upgrading to MAC OS X Yosemite » » » » Post: Re: Installed version 4.4 no longer working since upgrading to MAC OS X Yosemite |
Print at Oct 4, 2026, 6:51:04 AM |
| Posted by Puybaret at Oct 20, 2014, 11:16:41 AM |
Re: Installed version 4.4 no longer working since upgrading to MAC OS X Yosemite In the Java Web Start version, I noticed an issue in full screen mode on my iMac when I switch to that mode at launch and then try to open a document. The version 4.5 beta 14 available under Java Web Start should fix this issue. If you encountered an other scenario that provoked a crash or a freeze, please tell me. Be sure also to check if full screen mode works correctly in some other applications, because it could be also a bug in Yosemite itself, since it's still young. By the way, I'm astonished that it works so slowly under Java Web Start, and would like more details about this. How big is your project? How do .sh3d files available in the gallery work? I surely do not want to go back to Java 6, which has some security issues and is no longer supported The security issues were in Java plug-in used in browsers, not in Java core itself. I installed Apple Java 6 under Yosemite as proposed by the system at Sweet Home 3D launch, and could run it with no problem. Apple didn't update the look of user interface items shown in Java applications but unfortunately, neither did Oracle in Java versions 7u72 or 8u25 released last week.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 6:51:04 AM |
