Print at Sep 1, 2026, 8:58:11 PM
Posted by okh at Oct 22, 2014, 7:22:20 AM
Re: Window, door dimensions
1) Well the dimensionscan be changed successfully as long as the proportions are not too far off.
2) As for styles, there are so many kinds of windows and doors that pointing you in the right direction is almost impossible without knowing what you are after. But you can search for models on-line, and may find what you need (e.g. 3D Warehouse - use kmz format for import).
3) As for the icons and how the windows fit the wall, these are properties not included in the normal 3D formats, and therefore added to SH3D models (furniture library editor and advanced editing of properties).
4) Don't know whether my windows can be of use, see some 20 different examples for SH3D in SF 3d models 260, but feel free to use them. Or shout if there is a particular model you need - maybe someone else has already made your window...
The "materials" list you can extract from the furniture list (choose columns, sort, multiple select, copy / paste to spreadsheet) - albeit on item level only.
