Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: The dependence of the thickness of the door or window, the thickness of the wall in which they are embedded. » » » » Post: Re: The dependence of the thickness of the door or window, the thickness of the wall in which they are embedded. |
Print at Oct 4, 2026, 10:09:24 AM |
| Posted by okh at Oct 23, 2014, 12:22:36 PM |
Re: The dependence of the thickness of the door or window, the thickness of the wall in which they are embedded. Maybe the easiest of all is to use a separate frame and a door without door-properties? Allows you to change opening or hide the door altogether. Makes for a tidier work-space and to combine different doors and frames. But preferably so the 2d door-frame displays the way the door opens, like this. You will see that the scaling of the frame (how much the door frame protrudes from the wall) is still a "problem". But on a much smaller scale - and it is normal to use thicker framework on an outside wall. ok See SF 3D 334. |
Current timezone is GMT Oct 4, 2026, 10:09:24 AM |
