Print at Oct 2, 2026, 9:19:56 PM
Posted by okh at Oct 23, 2014, 1:02:34 PM
Re: The dependence of the thickness of the door or window, the thickness of the wall in which they are embedded.
create a model of a door or window that shows the radius (arc) of the opening in the 2D plan?
Yes you can, but not without editing the SH3D properties assigned to the (imported) models.
Arcs (door openings) are amongst extra properties that can be added in the SH3D properties (not supported by .obj files etc). But you can create a Furniture Library and do some manual editing of the PluginFurnitureCatalog.properties file. See thread 2006 and page 9-10 of the SVG guide. That is the way the protruding door frames and 2D door arcs were made in the file above. Here you can also add light sources, information etc.
