Print at Sep 29, 2026, 2:18:59 PM
Posted by Puybaret at Oct 25, 2014, 5:10:16 PM
Re: Problem with models from Archive3d.net
As explained in this blog article, the part of the program that handles 3DS file format, the one used on Archive3d.net, was updated in version 4.5. So, first, you should check if you use this version.
Then, if you still have problems, you should know that many 3D models proposed on that web site use texture images, that sometimes are missing or are at format not supported by Sweet Home 3D.
