Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Lateral view of indoor walls » » » » Post: Re: Lateral view of indoor walls |
Print at Oct 3, 2026, 1:24:30 AM |
| Posted by okh at Nov 27, 2014, 2:49:11 PM |
Re: Lateral view of indoor walls I agree that a horizontal (non-distorted) view could be useful. The question has come up before, e.g. thread 5416, also describing a couple of workarounds. Exporting a wall as .obj, re-import and rotate, add dimensions and texts, save as .svg and edit with (for instance) Inkscape, is a possibility. If you use multiple levels in Inkscape, keep wall outline on a lower level (with texture), dimensions on the next up, structural elements, plumbing, wiring symbols on top of that, etc. you can use different tools (layer opacity) to create a pretty accurate work-sketch. Not ideal, I suppose, and you need to get a feel for Inkscape (or whatever software you use) but result is not half bad. ok |
Current timezone is GMT Oct 3, 2026, 1:24:30 AM |
