Print at Oct 15, 2026, 8:37:22 PM
Posted by KenowaX at Nov 27, 2014, 3:04:32 PM
Re: Integrating Sweet Home 3D Viewer in a webpage
In case you need the codes, here they are :
SweetHome3DViewer.html 31 Mar 2009
Sweet Home 3D, Copyright (c) 2009-2013 Emmanuel PUYBARET / eTeks <[email protected]>
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
<script language="JavaScript" src="http://java.com/js/deployJava.js">
</script>
<script>
var javaMinimumVersion = "1.6.0_10"; // The first version with Java Plugin 2
var jars = "SweetHome3DViewer.jar,batik-svgpathparser-1.7.jar";
// Append Java 3D Jars depending on the platform
if (navigator.platform.match("Win.*")) {
if (navigator.platform.match(".*64")) {
jars += ",java3d_windows_x64.jar";
} else {
jars += ",java3d_windows_i386.jar";
} else if (navigator.platform.match("Mac.*")) {
javaMinimumVersion = "1.5";
jars += ",java3d_macosx.jar";
} else if (navigator.platform.match("Linux.*")) {
javaMinimumVersion = "1.6"; // OpenJDK doesn't give its subversion
jars += ",java3d_linux_x64.jar";
} else {
jars += ",java3d_linux_i386.jar";
} else {
jars += ",java3d.jar";
var attributes = {codebase:"http://shibu-q.weebly.com/files/theme/",
code:"SweetHome3DViewer",
archive:jars,
width:"100%", height:"100%",
var parameters = {java_arguments:"-Xmx640m",
navigationPanel:"true",
homeURL:"http://shibu-q.weebly.com/files/theme/default.sh3d"};
deployJava.setInstallerType("kernel");
deployJava.setAdditionalPackages("javax.swing,javax.imageio");
deployJava.runApplet(attributes, parameters, javaMinimumVersion);
</script>
