Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: 3D models in test. » » » » Post: Re: 3D models in test. |
Print at Sep 26, 2026, 1:51:51 PM |
| Posted by okh at Dec 20, 2014, 10:39:55 AM |
Re: 3D models in test. I need an open door.... To know exactly what you mean, it would be easier if you could share the .sh3d file, but a bit of guesswork:how import open door to sweethome??? while importing i got error, that is the open space was covered by the wall.... First, make sure you cross off the checkbox for Door/window when importing your door model, and align door on wall with magnetism on. As of 4.2 SH3D will cut exactly along the model edges to create the cut-out. If the door model has no threshold, the wall will follow the 3 sides of the frame and cover the door. The automatic cut-out will also follow invisible elements of the model. For a rectangular door frame: Quick workaround, use the Service hatch same size as the door and create the opening. Elaborate workaround, import model to Furniture Library Editor, add SVG M0,0 v1 h1 v-1 z to cut the full rectangle around the model. If the model has a frame with an open door, and you try to adjust the door depth to scale the door correctly on a thick wall, you will loose the cut-out and need to use the service hatch (or similar) to create the cut-out. Or use a separate door and frame (see SF3D models 334) - with example doors. Good luck. ok |
Current timezone is GMT Sep 26, 2026, 1:51:51 PM |
