Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Reality Check » » » » Post: Re: Reality Check |
Print at Oct 3, 2026, 10:43:25 PM |
| Posted by slimpy at Jan 1, 2015, 2:32:55 PM |
Re: Reality Check People who work professionally in Architectural visualisation generally make post-process of the images (once they are been rendered with their 3D modeller program) using Photoshop. I mean, the only render never is enough for a realistic or final high quality image. So, if you want to improve the final render with photoshop, to get a more realistic result, just go on. It is a standard practice in arch-vis. The main goal was to find out how accurate and realistic you can get with SH3D. This rules out any post processing of the rendered images. I find the result quite satisfying. I also like the fact that I can reproduce the exact same result anytime. I can also change perspective, zoom in and out and render new images at the same quality quite easily. There's a lot more work to do if you add in post processing in a third party program. Best, slimpy |
Current timezone is GMT Oct 3, 2026, 10:43:25 PM |
