Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: HELP for designing my mansard » » » » Post: Re: HELP for designing my mansard |
Print at Oct 5, 2026, 12:13:32 PM |
| Posted by okh at Jan 11, 2015, 10:28:07 AM |
Re: HELP for designing my mansard Looked at your construction and it seems to me as if the crossbeams could be drawn with the method described above: use a blank file to draw the beam as a low wall 'laterally' so you get the correct angle, and then export-import-rotate selection. (Btw, you can control the angle of the end of the beam by adding connected walls that you do not export). But maybe I misunderstand? As for the roof itself, maybe the triangle roof shapes in SF 3D models 330 can be of help? ok |
Current timezone is GMT Oct 5, 2026, 12:13:32 PM |
