Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Inclined wall at 45 degree with the ground » » » » Post: Re: Inclined wall at 45 degree with the ground |
Print at Oct 17, 2026, 2:24:27 AM |
| Posted by okh at Jan 21, 2015, 4:20:54 PM |
Re: Inclined wall at 45 degree with the ground Alas, standard walls cannot be angled, but using the roof principle, the fix is relatively easy: Draw the wall, insert windows, select wall+windows, export selection as .obj, import and rotate. Then you need to angle (slope) the ends of the joining walls (if the angle leans inwards) or fill gap with triangles (if it leans outwards). ok |
Current timezone is GMT Oct 17, 2026, 2:24:27 AM |
