Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: SH3D 4.6 » » » » Post: Re: SH3D 4.6 |
Print at Oct 1, 2026, 5:32:23 AM |
| Posted by Puybaret at Feb 4, 2015, 12:39:49 PM |
Re: SH3D 4.6 You're welcome ![]() I hesitated to distribute it as a small 4.5.x update for Mac OS X only, but finally chose version 4.6 because the API was modified and some minor changes were programmed. Among other things, it's now possible to zoom closer in the 3D view when the plan contains some walls and is less than 10 meters wide. I also changed a parameter in the 3D view to better manage transparent items shown being each other (see this bug). To make the update more interesting for Windows users, I changed the installer to propose the 64 bit version it contains with a max memory set to at least 2 GB. This should help the 64 bit system users who couldn't render photos for big designs with default max memory setting. If I get no bad feedback on this change, I shall change the SweetHome3D command for Linux 64 bit in the next version too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 5:32:23 AM |
