Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Remove imported library? » » » » Post: Remove imported library? |
Print at Sep 30, 2026, 5:21:33 PM |
| Posted by onefish at Mar 2, 2015, 2:39:05 AM |
Remove imported library? I am new to SH3D and I'm still working out how to use it properly and get all the furniture I need imported. I just tried removing all colours from an item in Sketchup, then exporting to dea format then created a library using the furniture library editor and imported into SH3D. There is only the one item but the library editor allowed me to specify the category as kitchen. My thinking was that with all colours removed I should be able to modify the object colour in SH3D whenever I used the object. Well that didn't work so good, just doesn't look right at all. So I will go back to the Sketchup version and create several separate versions in different colours then export/library/import/etc. The problem is that I now have the item in my library that is no good and I'd like to remove it but cannot seem to find a way. I found a post here that suggested right click and remove but I don't have that option in the context menu. The item label is not in italics either. ??????? Cheers! |
Current timezone is GMT Sep 30, 2026, 5:21:33 PM |
