Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Remove imported library? » » » » Post: Re: Remove imported library? |
Print at Sep 29, 2026, 5:35:13 PM |
| Posted by onefish at Mar 2, 2015, 11:29:03 AM |
Re: Remove imported library? Thanks Puybaret, that worked once I figured out what you meant. 1) go to the help menu in the application and select "about" 2) select "libraries" from the popup box 3) locate the library you want to remove and select the link 4) a standard explorer window will open, select and delete the SH3F file for the library you want to remove 5) restart the application. Hansmex, thank you as well. I actually found a suitable solution, or should I say that I learned a fair bit more about how Sketchup works. I ended up having to explode all polygons, remove all fill colours, remove colours for faces as well in another menu, and then select the somewhat hidden option to export 2 sided object to dae. I was then able to just add the colours I wanted within SH3D and it looks good. I now have tolix chairs and stools in a rainbow of colours! |
Current timezone is GMT Sep 29, 2026, 5:35:13 PM |
