Print at Sep 1, 2026, 4:10:05 PM
Posted by Desslok at Mar 7, 2015, 1:29:50 AM
Re: Import models, textures problems.
Try this. In Blender, create a special folder where you intend to save the object file. Copy all related textures into that folder. Then when you apply your textures use these as your source. Then export as obj format, saving the object file into that folder. Then open that folder and zip the contents into a single zip file. Then open the furniture library editor and load the zip file into that. The object should come in will its textures intact. Make any modifications necessary, assign it to a furniture catagory and then save the furniture library. Then import the furniture library into Sweethome3d. It should work. It does for me. I have the same problem trying to import the furniture directly into the program so I use the Furniture Editor as an intermediate step.
