Print at Sep 29, 2026, 8:34:26 AM
Posted by ggrinton at Mar 26, 2015, 12:18:09 AM
Re: Windows version crashes after startup with Java <binary has stopped working> error
Thanks for the suggestions. I have downloaded the jar file, and tried that. When I run it, a java error log file is created immediately.
I tried the 2D invocation as per the FAQ and that works, so I suspect the problem is in the rendering system. My drivers and DirectX drivers are all up to date.
Geoffrey.
Here are what I think are the relevant sections of the error log:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000005efde058, pid=50196, tid=52536
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [nvoglv64.DLL+0x95e058]
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x0000000058f3d800 JavaThread "J3D-Renderer-1" [_thread_in_native, id=52536, stack(0x000000005cdc0000,0x000000005cec0000)]
0x0000000058f3d000 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=51972, stack(0x000000005cc20000,0x000000005cd20000)]
0x0000000058f29000 JavaThread "J3D-NotificationThread" [_thread_blocked, id=53000, stack(0x000000005cb20000,0x000000005cc20000)]
0x0000000058ee5000 JavaThread "J3D-TimerThread" [_thread_blocked, id=45800, stack(0x000000005c860000,0x000000005c960000)]
0x0000000058ee3000 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=52952, stack(0x000000005c750000,0x000000005c850000)]
0x0000000058c7d000 JavaThread "pool-2-thread-1" [_thread_in_native, id=52368, stack(0x000000005aee0000,0x000000005afe0000)]
0x0000000058c76000 JavaThread "pool-1-thread-1" [_thread_blocked, id=52844, stack(0x000000005bdc0000,0x000000005bec0000)]
0x0000000058e1f000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=34512, stack(0x000000005bac0000,0x000000005bbc0000)]
0x0000000058e43000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=30368, stack(0x000000005b060000,0x000000005b160000)]
0x0000000058e81000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=45936, stack(0x0000000059430000,0x0000000059530000)]
0x0000000056aa9000 JavaThread "AWT-Shutdown" [_thread_blocked, id=50408, stack(0x0000000058920000,0x0000000058a20000)]
0x0000000058bfc800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=52456, stack(0x0000000058440000,0x0000000058540000)]
0x00000000567fd000 JavaThread "Service Thread" daemon [_thread_blocked, id=50940, stack(0x0000000058330000,0x0000000058430000)]
0x0000000056787000 JavaThread "C1 CompilerThread3" daemon [_thread_blocked, id=52444, stack(0x0000000058090000,0x0000000058190000)]
0x000000005677e800 JavaThread "C2 CompilerThread2" daemon [_thread_blocked, id=49824, stack(0x0000000058190000,0x0000000058290000)]
0x0000000056777800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=49420, stack(0x00000000576b0000,0x00000000577b0000)]
0x0000000056772800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=44388, stack(0x0000000057f70000,0x0000000058070000)]
0x000000005676d000 JavaThread "Attach Listener" daemon [_thread_blocked, id=33816, stack(0x0000000057df0000,0x0000000057ef0000)]
0x000000005676c000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=27820, stack(0x0000000057c40000,0x0000000057d40000)]
0x00000000555a8800 JavaThread "Finalizer" daemon [_thread_blocked, id=50504, stack(0x0000000057910000,0x0000000057a10000)]
0x000000005559f800 JavaThread "Reference Handler" daemon [_thread_blocked, id=50796, stack(0x0000000057a40000,0x0000000057b40000)]
0x000000000019f000 JavaThread "main" [_thread_blocked, id=36920, stack(0x00000000022a0000,0x00000000023a0000)]
