Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to fill in blank space between walls and 6 corner bathtub » » » » Post: Re: How to fill in blank space between walls and 6 corner bathtub |
Print at Sep 28, 2026, 10:57:45 PM |
| Posted by shanghai_nin at Apr 1, 2015, 5:16:20 PM |
Re: How to fill in blank space between walls and 6 corner bathtub Hello, the issue is that only one triangle is not enough, there is both a space between the two walls and the tub. 2 boxes and 1 triangle might do the trick, however this is not one surface how I would like it to be. Is there an add command (not only group) to add 3 separate items into one (a boolean +) ? Greetings |
Current timezone is GMT Sep 28, 2026, 10:57:45 PM |
