Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Printing and exporting to pdf to size B0 fails » » » » Post: Re: Printing and exporting to pdf to size B0 fails |
Print at Sep 25, 2026, 2:06:28 PM |
| Posted by Puybaret at Apr 11, 2015, 10:25:51 PM |
Re: Printing and exporting to pdf to size B0 fails I remember there was a bug in Java that prevented to use the margin set in Page Setup panel. To circumvent this issue, you can define the com.eteks.sweethome3d.swing.fixedPrintMargin property with a value equal to the desired margin in centimeter. To set this property with a value equal to 0.2 under Linux, edit the SweetHome3D script and add the following text after java: ‑Dcom.eteks.sweethome3d.swing.fixedPrintMargin=0.2---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 2:06:28 PM |
