Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: No 3D panel with SweetHome 4.5 on Debian Jessie » » » » Post: Re: No 3D panel with SweetHome 4.5 on Debian Jessie |
Print at Oct 5, 2026, 9:40:04 PM |
| Posted by jbernon at Apr 21, 2015, 10:39:42 AM |
Re: No 3D panel with SweetHome 4.5 on Debian Jessie Thank you for your answer Hans. I can already use Sweethome through Windoxs 7. I would like to use it through my Linux dist which is the new Debian 8 release (kernel 3.16.2). Using Ubuntu 14 for one app doesn't make sense in my environment. I will try again to make sh3d working with Debian 8 (also called Jessie). sh3d is part of the main dist packages and it should work. Here are the Debian packages : - sweethome - sweethome3d-furniture Here are the sweethome package dependancies : - icedtea-netx-common | sun-java6-bin - javawrappers - libfreehep-graphicsio-svg-java - libitext-java - libjava3d-java - libsunflow-java - libbatik-java - default-jre | java6-runtime In your opinion, what is to be checked in this stuff ? Is there any probability to get it working ? |
Current timezone is GMT Oct 5, 2026, 9:40:04 PM |
