Print at Oct 6, 2026, 12:18:04 AM
Posted by storm88 at Apr 27, 2015, 4:31:08 PM
Guide: Pipes
Hello, I used SweetHome3D extensively during reconstruction of my home and I thought I share some tips with you. This one is about pipes, wires, etc
It might be useless for most of you, but you can use sweet home to plan, design, and visualize all pipes. It is easier than you might have thought.
attached you can see some pictures what the result will be and the sh3d file so you can examine details. Apologies for not having names in english.
images: http://postimg.org/gallery/1r5bge49a/
sh3d: http://s000.tinyupload.com/?file_id=08836581788377803731
This plan is my hot and cold water (blue) and waste water (orange). beside these I also have one for heating, air vents, gas, some electrical collectors. they all are in separate plans to prevent confusion.
How to get these in 12 steps:
1) make sure you have most precise plan possible. it's pain in the ass to change dimensions in 10 different versions of plans
2) decide on colors before you start. repaint many objects can be time consuming and boring.
3) delete all stuff not directly related to what you need (furniture, etc). Dont use rooms as they will prevent you see through floors
4) set all walls height to 1 cm (or less), make them look black in 3d view. this way you'll see the floor plan and pipes that are in walls. You will place pipes inside walls and you want to be able to see them in 3d view.
4a. you can achieve similar with invisible walls, but this might be better. whatever suits you
4b. you can keep windows and doors in your plan, group them by level and make them hidden so they don't block your view. Then you can make them visible only if needed.
5) use "box" and "cylinder" to create pipes. Might look like pain in the ass but once you get used to it, it can be done pretty quickly.
6) name your objects (pipes and walls) so you don't get lost. really. Such as "vertical hot water kitchen" and so on.
7) you can't (sufficiently) make pipes that are under floor level. expect this for high precision plans, if you also plan to have height etc.
8) place legend somewhere so when you print it you don't get confused. Mine is on the bottom floor. each legend has '= in front of it. = to identify it's a legend and not get it confused with the real stuff and ' to prevent excel thinking the legend is a formula when i export csv of furniture.
9) never mix dimensions. for all pipes, assume WIDTH is the longest dimension, and keep it so for all pipes.
10) re-sizing pipes is complicated. say you have depth of 5 cm and want to make your pipe wider. after you manually drag and drop it, you will most likely have depth 5.3 or something. don't worry at this point, make sure all your pipes are exactly as wide as you want them and then change depth of all pipes you edited to 5. This is a big time saver.
11) avoid dimensions than 5 cm. you will have hard time seeing them.
12) you can select "color" column in furniture view to sort your pipes by type
I hope I have not forgot anything important. I also be happy if you have some improvements.
If you like it, leave a comment and I'll add some more tips on how to use SweetHome3D beside room design.
