Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 5.0 » » » » Post: Re: Sweet Home 3D 5.0 |
Print at Oct 2, 2026, 7:57:03 PM |
| Posted by Puybaret at May 7, 2015, 6:47:25 PM |
Re: Sweet Home 3D 5.0 Thanks for your feedback ![]() Could that plug-in be integrated in the main program? It's not what I plan at the moment.Edition > Paste No, I don't think so Probably this is franglais? ![]() It lets you copy the color/texture of a given copied object on others selected objects of the same kind without displaying again their modification dialog. It can be also used to keep in memory the color/texture of a room for example, when the quickest way to recompute a room is to delete it then recreate it with a double-click. Note that you can copy the style of a room only on rooms, copy the style of a wall only on walls,... and there should be only one object in the clipboard to enable this new menu item. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 7:57:03 PM |
