Print at Oct 4, 2026, 3:39:07 PM
Posted by hansmex at May 9, 2015, 4:12:28 PM
Re: Negative Elevation for Furniture
1 - Click the plus button to add a level. Set elevation to zero, rename it to level zero/slab. Draw a room the size of your slab. Set floor thickness to 15 cms.
2 - Change elevation of level zero to 15 cms. Use CTL-A to select all walls and modify their height.
3 - adjust elevation of level one.
Now you should have a a ground floor level with a slab. A lower level with a veranda, and an upper level with the rest of the house.
To solve a problem (or describe it in this forum) it helps to analyze it.
- level 0 = slab = 15 cms high ?
- level 1 = veranda = xxx cms above slab ?
- level 2 = house = 10 cms above veranda ?
Maybe you could try and sound les grumpy? I don't get paid to solve your problems and/or teach you the use of CTL-A...
