Print at Oct 6, 2026, 10:29:37 PM
Posted by okh at May 13, 2015, 9:00:23 AM
Re: Want to use software for Feng Shui evaluation...
Now that I think about it, there is already a protractor in the 2D plan: The compass. Move it to where you want it and scale (East/right) and rotate (South/bottom) to show angles. But as the compass appears below rooms, you will need to be comfortable with select / de-select functions to move it around easily (or rely on Undo or Plan-Modify compass to move away from construction).
Also, possibly a background image with your desired angles can be of help. ok
