Print at Sep 1, 2026, 12:24:34 PM
Posted by Puybaret at May 14, 2015, 7:49:55 PM
Re: SH3D portable - Videos are created but storing results in 0 byte files
It's quite strange because if the work folder couldn't be created, I think that the video creation process would abort much earlier.
Maybe, try to set the com.eteks.sweethome3d.applicationFolders Java system property equal to a folder where you're sure you can write, for example by writing:
-Dcom.eteks.sweethome3d.applicationFolders=C:\Windows\Temp
in a text file named SweetHome3D.l4j.ini and saved in the same directory as SweetHome3D executable files.
