Print at Sep 29, 2026, 11:26:40 AM
Posted by Puybaret at May 21, 2015, 8:12:42 AM
Re: 4.6 upgrade doesn't work
I don't see any difference between these two versions that could have caused this problem.
Are you sure it's version 4.5 that works and not version 4.2 or a previous version? Because from version 4.3, the installer version forces to run the 64 bit version of the program and some 64 bit drivers have more problem than their 32 bit counterpart. In that case, you should install Java 32 bit and run Sweet Home 3D with Java Web Start.
