Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How can the floor be inside the top of the lower level? » » » » Post: Re: How can the floor be inside the top of the lower level? |
Print at Sep 30, 2026, 9:22:48 PM |
| Posted by bert.struik at May 22, 2015, 8:09:34 PM |
Re: How can the floor be inside the top of the lower level? Okay. I think its solved now. Thank you very much for your help. Here is what I wanted, shown as a cross-section through the foundation and walls. What your tips told me is to create, where necessary, levels with fake walls or fake floors. So this is what I did. 1. Created level 0 for the footing (elev. -24, height 8, first level did not ask for floor thickness) 2. Drew a wall in level 0 for the footing (height 8", thickness 24") 3. Created level 1 for the foundation wall (elev. -16, floor thickness 0.125 (minimum permitted), height 24") 4. Drew a wall in level 1 for the foundation wall to width and length of the building exterior (height 24", thickness 6") 5. Created level 2 for the concrete slab (elev. 8", floor thickness 4", height 4") 6. Drew a fake wall in level 2 inside the wall of level 1 ( (height 0.125" (min. permitted), thickness 6"). That exposed the 4" floor of level 2 and forced it to stop inside the foundation wall of level 1. 7. Created level 3 for the wood frame wall to rest on the foundation wall of level 1 (elev. 8", floor thickness 0.125" (fake floor), height 120") 8. Drew the wood frame wall in level 3 (height 120", thickness 6") It would work better if floor height and wall height could be set to 0. here is link to the test drawing with those parameters. foundation_test.sh3d Thanks again. |
Current timezone is GMT Sep 30, 2026, 9:22:48 PM |
