Print at Oct 1, 2026, 2:18:09 AM
Posted by mazoola at May 25, 2015, 11:09:44 AM
Re: Turning on lighting.
Bob -
As someone currently stuck using an underpowered, backup PC, I usually run a quick 'lighting check' run at low resolution (200 to 300 pixels wide) and level 3 quality; that's usually enough to sanity-check most lighting options. (IIRC, only a few, higher-level ray-tracing features [reflection, refraction] show up only at level 4.) Once I've adjusted lighting to eliminate burnout and shaded areas, I render at full size and level 4.
Maz
