Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 5.0 » » » » Post: Re: Sweet Home 3D 5.0 |
Print at Oct 2, 2026, 11:13:16 PM |
| Posted by Puybaret at May 31, 2015, 6:08:59 PM |
Re: Sweet Home 3D 5.0 Doors open outwards have a problem Please, send me your test file.![]() It seems baseboards are limited to 2 cm thickness, but can be very high (?). If so, I am curious as to the reason. The reason is that I don't see why a thickness of more than 2 cm should be necessary, and a higher thickness would require an "additional option to colour or texture the top of them" as Hans said. About the height, it's just that I didn't program any control on it yet. Actually, it should be forbidden to set a higher value for a baseboard height than the wall to which it belongs, so if the user reduces the height of the wall, the baseboard height should start to reduce too as soon as the wall height becomes smaller than the current baseboard height. I admit I was a little lazy on this but I'm going to fix it, even if changing the baseboard height in the back of the user doesn't please me too much (the baseboard height is not visible when the user changes the wall height). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 11:13:16 PM |
