Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: I'm in a trouble please help » » » » Post: Re: I'm in a trouble please help |
Print at Sep 1, 2026, 11:03:23 AM |
| Posted by okh at Jun 18, 2015, 7:56:53 AM |
Re: I'm in a trouble please help Well, from your screengrab, it seems some of your files have been corrupted. But many look good. 1) Did "C:\Users\رنا\Application Data\eTeks\Sweet Home 3D" already exist? I am asking because on my win 8.1 computers, data files are stored either in "C:\Users\xxx\eTeks\Sweet Home 3D" or "C:\Users\ok\AppData\Roaming\eTeks\Sweet Home 3D". So maybe the directory is wrong? 2) But never mind that, now that you have found most of your files, I guess they can be salvaged manually. If I get this correctly, at least that is the way it is here, the .pref files you have found are really various compressed files. The larger files are likely to be the .zip versions of your furniture: - COPY all the .pref files to an extra directory where you can mess with them (keep a backup), - rename a large file to .zip instead of .pref as extension, - open SH3D, - drop the .zip file into the SH3D window. IF the .zip file is in fact zipped furniture, it will import normally. IF SH3D tells you the format is unsupported, it is probably not a zip (but an image file, I think). - repeat with next large file. The remaining smaller files, will be I think, .png files with images of the imported furniture. Which you can ignore as the image will be generated again when you import (I think). ok PS 1: you can also check the files first. Rename all files to .zip and try to open them in Windows. If they are .zip, they will open. PS 2: If you have used your furniture in projects (.sh3d files) you could copy and salvage them from there. |
Current timezone is GMT Sep 1, 2026, 11:03:23 AM |
