Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: floor connects through corners » » » » Post: Re: floor connects through corners |
Print at Oct 6, 2026, 1:13:41 AM |
| Posted by kollmerized at Jun 25, 2015, 11:46:58 AM |
Re: floor connects through corners sadly it doesn't work, the plugin won't work properly because the walls which symbolises pillars won't be recognised very well, resulting in diagonal walls. The same happends if i manually correct the start / endpoints of the walls, at the pillars the walls will be centered leading to diagonal walls. Some Walls have to start in center of one side of the pillar while others don't (see image in first post isn't there a way to deactivate the connection of the rooms? |
Current timezone is GMT Oct 6, 2026, 1:13:41 AM |
