Print at Oct 18, 2026, 5:35:47 PM
Posted by Puybaret at Jul 21, 2015, 9:00:25 AM
Re: advice needed
Add a level and change its elevation to a negative value. Then in Virtual visit mode, you can below the ground and all objects you'll add to this underground level (a closed set of walls, rooms, furniture) will create a hole in the ground.
