Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Unable to make it work on Mac » » » » Post: Re: Unable to make it work on Mac |
Print at Sep 24, 2026, 2:39:47 PM |
| Posted by Puybaret at Jul 25, 2015, 8:28:05 PM |
Re: Unable to make it work on Mac If you want to run it with Java 8, you can use the Java Web Start version or the Jar executable version. As far as I understood, you already downloaded the SweetHome3D.jnlp file that will let you run the Java Web Start version. To run the program with that file, you now have to right click on this file or, if you didn't enable right clicks on your Mac, press the ctrl key and click on the file to display the contextual menu. Then just choose the Open menu item in the contextual menu, and answer security questions. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 2:39:47 PM |
