Print at Sep 1, 2026, 9:40:23 AM
Posted by hansmex at Aug 11, 2015, 2:23:04 AM
Re: Rotating model other than 90 degrees
Why don't you draw your building in sync with the background? When it's ready you can change the compass orientation to point the building in the right direction.
Otherwise it might be easier to rotate the background.
A third option might be to rotate the building after it is finished. Export and import the whole lot, then rotate around the x,y axis.
