Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Glass box angled to vertical » » » » Post: Re: Glass box angled to vertical |
Print at Oct 18, 2026, 8:42:23 PM |
| Posted by okh at Aug 11, 2015, 10:35:10 AM |
Re: Glass box angled to vertical I may still not quite get it... Is your concept the same as in thread 5601? Sent you an example by e-mail. You can change the rotation of an object while importing, but once it has been imported the rotation is no longer available from inside SH3D. Hence it will skew when dimensions are changed (disproportionally). Which means you must export to .obj and re-import to get a new rotation without distortion. Or, you could use the furniture library editor to change the rotation of the object in a library. But again, maybe I miss something here. ok |
Current timezone is GMT Oct 18, 2026, 8:42:23 PM |
