Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: door size jumps, if I move into the wall » » » » Post: Re: door size jumps, if I move into the wall |
Print at Sep 1, 2026, 9:34:41 AM |
| Posted by Puybaret at Aug 17, 2015, 7:11:02 AM |
Re: door size jumps, if I move into the wall About the issue with the door, please read the workaround proposed in this ticket. About the "melted" walls, I'm not sure to fully understand what you mean. If you have two walls that are superimposed in the plan and you want to remove one, maybe you could right click on the walls and choose the one you want in the Select object menu that will appear in the contextual menu. Then just delete the selected one. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 1, 2026, 9:34:41 AM |
