Print at Oct 16, 2026, 1:15:16 PM
Posted by siddie at Aug 20, 2015, 8:10:07 AM
Re: Section view - create 2D cut through the building to complement floorplan
Thank you Hans and OK!
The term "cross section" helped me out to search for the right thing and i could find the workaround that OK suggested now as well.
This should be enough for my needs. I can remove all the walls and elements except the 1 wall including windows etc., export and import it while rotating to put it on the ground. Then i can add all the measures needed.
Excellent, thanks again.
Maybe one last question just out of interest: why is it, that the imported .obj file is as unsharp as in the example of OK?
Thanks,
Siddie
