Print at Sep 1, 2026, 8:18:41 AM
Posted by JUGGERNAUT at Sep 10, 2015, 9:07:05 AM
Re: Questions from a newby
When you select the specific wall to "paint", in your modify walls toolbox, you will see that you have two sections to modify either side (inside or outside) of the selected wall. Once you've selected a specific side with the colour paint, click ok and look at the 3D view if the correct wall is painted/coloured. If not, press undo at the top of your design window and then go back to the modify window to select the other side of the wall with your colour preference. (remember not to de-select your wall you are trying to modify)
I basically did my wall colouring using a "trial and error" approach.
Hope this was helpful
Juggernaut
