Print at Oct 17, 2026, 6:27:23 PM
Posted by okh at Sep 25, 2015, 9:36:04 AM
Re: Select items in full house
To the best of my knowledge, there is no list of walls and other construction elements.
But if you select the items you want from the furniture pane (multiple select using CTRL), and then select the walls form the 2D pane with SHIFT, you can combine and copy. In fact, using area select with combinations of CTRL and SHIFT does let you select multiple different elements.
Or am I missing something?
