Print at Oct 4, 2026, 12:53:28 PM
Posted by okh at Oct 3, 2015, 1:08:56 PM
Re: Import models from Blender
This should not be a problem if Blender exports .obj to the same directory you later use when importing to SH3D.
Note that the .obj format can consist of two or more files. If in Blender you export to Wavefront/OBJ, you should see .obj,.mtl (on top in the export menu). Blender will then generate the two files. The .obj file links to the .mtl file - so they should be kept in the same directory. The .mtl file can again link to texture files which could be elsewhere or in same directory (you may need to study the .mtl file with a text editor to find missing files).
