Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 5.1 » » » » Post: Re: Sweet Home 3D 5.1 |
Print at Oct 1, 2026, 2:14:01 AM |
| Posted by Puybaret at Oct 4, 2015, 10:51:00 PM |
Re: Sweet Home 3D 5.1 Thanks okh for your tests. I understand your need about multiple tabs selection but sorry, I won't program this feature in the coming version (not sure it can be achieved easily, and I would have to find a way to render selected level tabs at screen). But the version 5.1 will bring some fixes about some bugs you reported: - The bug #623 about some parts at ground level that shouldn't appear is fixed. - The older bug bug #582 about staircase cutouts that were wrongly computed is fixed too. Actually, this bug correction fixes also some rendering issues that could still happen on rooms at ground level. - I fixed also a bug that could prevent to reopen a file saved with its furniture list sorted on Color or Texture columns, when running Sweet Home 3D under Java 8. As this issue could be very annoying, I will release the new version with these bug fixes very soon, and you can test the corrections in the Beta 3. About texts in SVG files, I guess it's the choice of the team of FreeHep (the library used by Sweet Home 3D to generate SVG files). At least, you're sure your SVG file won't require a particular font to look correctly or won't depend on a font that would require some non latin characters. About an option to avoid raster images in the SVG file, what would you display instead of the textures and furniture images ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 2:14:01 AM |
