Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SH3D on Linux/Ubuntu » » » » Post: Re: SH3D on Linux/Ubuntu |
Print at Sep 1, 2026, 4:53:36 AM |
| Posted by digitaltrails at Oct 19, 2015, 4:11:34 AM |
Re:
SH3D on Linux/Ubuntu If SH3D is already running OK why would you consider an OS switch? You may run into other issues under Linux. Having said that, all the desktops in our home are 64 bit OpenSUSE 13.1. I'm using the Linux 64 bit SH3D with bundled-java. It works very well. The one small annoying issue with Java under Linux is that it will only output to paper sizes available on my local printers. I tried playing games with virtual printers, but I haven't worked out a convenient solution. This means I cannot produce large A3 PDF's from SH3D under Linux. |
Current timezone is GMT Sep 1, 2026, 4:53:36 AM |
