Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Copy'n'paste multi layer house » » » » Post: Copy'n'paste multi layer house |
Print at Sep 29, 2026, 9:18:26 AM |
| Posted by swave at Oct 25, 2015, 6:54:19 PM |
Copy'n'paste multi layer house Hi I have designed a house in and out. Now I want to see the effects and lighting with surrounding houses which are the same or mirrored. For mirroring I want to use the advanced plugin. However I have already a problem that the copied house is not correct anymore. It seems like the height over ground or the layer property is not saved correctly. It also depends on which layer is active while pasting. But I couldn't find a way to copy a multi layered house in one action. Workaround may be to copy'n'paste each layer separately but that's quite some work, especially as the layers need to be aligned again after pasting. Is my observation correct or am I doing something wrong? How can I copy and mirror a multi level house? Thanks |
Current timezone is GMT Sep 29, 2026, 9:18:26 AM |
