Print at Oct 17, 2026, 5:17:37 AM
Posted by okh at Oct 26, 2015, 2:42:04 PM
Re: Partially functional library edition
Hi again, had a quick look at your libraries. FurnitureLibraryEditor / SH3D stopped loading after model #5. So it seemed the error was related to model #6. Turns out there was only one specification of colour and diameter, not three (not that easy to spot at a glance, I keep doing similar errors all the time) . If you add the missing properties, for instance with the values in red below, the library works. Also sent you a private message about some copyright issues you may want to consider. ok
## Contributions models
id#6=Snduc#neon
name#6=Fluorescent strip
creationDate#6=2009-04-19
category#6=Lights 2
icon#6=/Neon.png
model#6=/Neon/neon.obj
width#6=42.0
depth#6=6.4
height#6=5.0
dropOnTopElevation#6=-1
movable#6=false
doorOrWindow#6=false
## modification (enkonyito)
lightSourceX#6=10.7 21.0 31.7
lightSourceY#6=2.2 2.2 2.2
lightSourceZ#6=2.5 2.5 2.5
lightSourceColor#6=#aaaaaa #aaaaaa #aaaaaa
lightSourceDiameter#6=4.0 4.0 4.0
elevation#6=200.0
creator#6=Snduc
