Print at Oct 17, 2026, 5:17:41 AM
Posted by okh at Oct 26, 2015, 2:55:21 PM
Re: Partially functional library edition
..the Furniture Library Editor as well as Sweet Home 3D don't try to set some default values that could correct the wrong lines...
Maybe that is even scarier, then I see my own confusion rising to even higher levels by getting strange default values. Actually, I think the perfect interface is the one you implemented with the SVG input, that it turns red when values are invalid. Just an error message could be a decent substitute (model #6 invalid... or something).
However, system works quite well as it is once you are used to it. But the real time-saver would be accessing all properties from the FurnitureLibbraryEditor (if only opening PluginFurnitureCatalog.properties as a text file - but then maybe the original file should be saved so it is possible to revert).
