Print at Oct 17, 2026, 5:17:46 AM
Posted by okh at Oct 29, 2015, 8:07:28 AM
Re: Partially functional library edition
As free 3D models have different licenses, can they be grouped under a common license in one library for redistribution?
If yes which one?
Afraid not. I do not think it is possible to find a "lowest common denominator" to match the different licences.
If I look at your library, my initial feeling is that you at least should provide information about the changed model. The information property in SH3D is quite useful for this:
information#6=Original model provided by Snduc (licence xx xx xx) in library <a href="xxx">, SH3D light properties modified by enkonyito..
My concern is if SH3D reads two models with identical id tag, in this case: id#6=Snduc#neon, will the second overwrite the first? If it does, Snduc might not be too pleased: that his/her well thought out properties were erased/altered by someone else. But even if the original is not overwritten, it should be made clear that the light properties are not the original ones.
This virtual gallery is an example of how you could use the information property so the info follows the model in SH3D.
