Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Doing a decor in bathroom » » » » Post: Re: Doing a decor in bathroom |
Print at Sep 27, 2026, 4:40:07 AM |
| Posted by HawkDawg at Nov 4, 2015, 6:55:24 AM |
Re: Doing a decor in bathroom No, I mean add a new level. Click on the Plan button at the top and select Add level at same elevation . Then you go back to the Plan button and select Modify level to change the elevation of the new level, but make sure you have the new level selected at the top of the plan pane. You can't change the elevation of a wall. You can only change the height. You have to create a new level to be able to adjust elevation, which is what you will need to do to be able to build a wall on top of the other wall. ---------------------------------------- Hawk |
Current timezone is GMT Sep 27, 2026, 4:40:07 AM |
