Print at Sep 29, 2026, 7:55:18 AM
Posted by Puybaret at Nov 4, 2015, 5:08:05 PM
Re: Standalone Furniture Library Editor Issues?
An OBJ or 3DS file doesn't specify the unit of the values it contains (but DAE files do), and Sweet Home 3D always interprets them as centimeters.
So if the designer didn't use centimeters for his model, you'll have to rescale it. Sometimes, the values are even not expressed in any unit.
Similarly, a designer can draw his model deciding the vertical axis will be along Y or Z. If he chose the wrong axis, you'll have to rotate it too.
