Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Sauna interiors » » » » Post: Re: Sauna interiors |
Print at Sep 25, 2026, 12:10:10 PM |
| Posted by okh at Nov 8, 2015, 9:51:55 AM |
Re: Sauna interiors I hope that the link opens - It is not necessary - but beautiful. - as image, no, but as link it works. And, yes, very nice. Kiuas / lauteet translate to stove / benches - if google-translate does not deceive. In which case doing a 3D Warehouse search for sauna ought to help you find interior. Also playing around with the words sauna and stove - and sauna and bench could give usable results. For modern saunas there are certain standards used, such as having the door on the same wall as the stove, where the ventilation should be placed and drainage. Also, the door must satisfy certain safety requirements so you are not locked in. Walls should satisfy certain minimum insulation requirements (something in the range of 100mm insulation + pine panel as extra layer against inner wall). But there are several handbooks available that will give you the details from the major sauna suppliers. ok PS. There is a Sauna kit (tiny tiny) in SF 3D models 370 - and some wood textures in SF 3D models 335 - just simple, seamless textures to illustrate (and keep model small). ![]() |
Current timezone is GMT Sep 25, 2026, 12:10:10 PM |
