Print at Oct 1, 2026, 4:29:18 AM
Posted by chriskano at Nov 23, 2015, 12:06:26 PM
Sweet Home 3D App Stops at Splash Screen
I'm trying to run the Sweet Home 3D 5.1 app on a Mac OS X 10.10.5 system that has Java 8 update 66 installed. When I launch the Sweet Home 3D 5.1 app it makes it to the splash screen and no further. It doesn't seem to crash, as I can eventually quit the program normally.
I've also tried the Java Web Start version and that seems to launch without a problem. I don't know why the Java Web Start version is launching properly, but the app is not.
If it is any help, the Java console that appears after the Java Web Start version launches displays the following:
Insecure property: (com.eteks.sweethome3d.applicationId, SweetHome3D#JavaWebStart) specified in unsigned jnlp file will not be set.
Insecure property: (com.eteks.sweethome3d.deploymentInformation, Java Web Start) specified in unsigned jnlp file will not be set.
Insecure property: (j3d.rend, jogl) specified in unsigned jnlp file will not be set.
Insecure property: (apple.awt.graphics.UseQuartz, true) specified in unsigned jnlp file will not be set.
3D [dev] 1.6.0-pre12-daily-experimental daily
Java Web Start 11.66.2.17
Using JRE version 1.8.0_66-b17 Java HotSpot(TM) 64-Bit Server VM
User home directory = /Users/chris
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
0-5: set trace level to <n>
Any ideas?
Thanks.
