Print at Oct 6, 2026, 1:14:58 PM
Posted by digitaltrails at Nov 26, 2015, 11:23:30 PM
Re: JAVA: How to change the default furniture catalog?
The properties and resources in the source (src) hierarchy are copied to the build output class hierarchy when the software is built by the build process. You would need to run ant to do a build.
I should have mentioned - see "copy todir" in the build.xml file.
